It worked really good for the last two weeks.
SOURCE: all pro 200t
It may be a reset switch on the heater. Usually located near where the electric supply goes into the unit.
SOURCE: I have an All Pro
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If
the units starts up and runs good and slowly goes out it will normally
be due to a lack of fuel getting to the nozzle. When there is not enough
fuel being delivered to the nozzle from either a clogged fuel filter of
dirty air pump output filter the unit will slowly shut down from lack
of fuel.
If the unit shuts down while it is running properly and
the nose come is orange then you probably have a problem with a
photocell or the flame out control.
If you have other questions you can contact our service department at 269-685-4125 at extension 224
Thanks
M Cramer
www.allpartsinc.com
SOURCE: I have a All Pro
Hi, Torpedo Heater Pump Pressure Adjustment
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
SOURCE: it keeps shutting on and
admin691,
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, how to fix the unit and where to get the parts, special tools and more information.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
SOURCE: i have a all pro
Hi First of all make sure that the heater is filled with K-1 kerosene. Other fuel, such as gasoline, burn too hot causing the heater to burn out of control. Never use gasoline or any other fuel described as flammable. If there is any question about the fuel in your heater it is best to drain it and replace the wick and start with fresh K-1 kerosene. If you are sure of your fuel and your heater is giving off sooty black smoke it is a sign that the fuel/air mix is off. Make sure the chimney is seated correctly. If it didn't seat into place correctly after lighting you may be getting a very high flame on one side. If it's a high orange flame all the way around try rolling the wick adjuster knob down within the adjustment range - the wick may just be too high. If these things do not fix the problem wait until the heater is cool and inspect the burner cylinder. If there are any holes plugged with soot it needs to be cleaned or if it's dented or buckled it needs to be replaced. After you have checked the fuel and burner you should check to make sure the wick is installed at the correct height. Refer to the owner's manual for exact height. If the wick isn't installed correctly or there is no obvious defect it is best to take the heater to a service center to determine the cause. Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
heatman101
heater...
Reddy
Torpedo
heatman101
Here is a tip about troubleshooting Torpedo Heaters
heatman101
