There are so many cases when people can't access the memory of the SD memory card.When you get connect with your system then it may need the driver to recognize the connected device.
The mobile phone comes with a driver or suit any thing which is associated with the mobile phone during purchase.You can install the driver and easily get access to your mobile phone and card memory both.
Some of the mobile phones are not being detected without the proper driver.
Samsung D780 drivers
You can access the memory of your card using the provided cable which can solve the problem.Just plug the cable into your phone and another end should be plugged with computer.
Wait for a while if it is not coming quick as you want.If the device is not being detected the you can use the device manager utility of the windows system.
Move to the My computer icon >Properties >Hardware tab> Device manager> .
Check your connected device in the list of Universal Bus Controller and if not find then move to the Control panel and use the Add new hardware wizard.
Another solution is:
Using Card Reader to access the files:
The memory can be accessed with one of the different methods but for this procedure you need to have another device called Card reader which is associated with a cable.
The memory can be accessed with this procedure :
1- Pull out the SD memory from mobile phone.
2- Use the card reader,insert the SD memory and plug this cable to computer.
3- Try to look, if the device is showing in the windows then it alright and your mobile phone has some disturbance regarding detection.
4- Just make the desired operation and if that is not being performed then you have to format the driver,I don't think any options is rest to try.
