SOURCE: torque specs. for outer tie rod ends for 2006
Tie rod end is 35 ft. lbs. Pinch bolt for the lower ball joint - 105 .I hope this helps you
Testimonial: "thanks for the help"
SOURCE: I need a electrical/wiring diagram for a 2001
For the entire Vehicle? Then go to alldatadiy.com. They have the most extensive and complete wiring diagrams I have ever seen or used. Cost is approximately $25 for a full 12-month subscription. The Haynes and Chilton Manuals only have "Generic" wiring diagrams, meaning they won't necessary match wire for wire to your specific vehicle. IF you know someone at a dealership service department or garage, ask them for copies of the specific area wiring diagrams you need. I do subscribe to alldatadiy and swear by them. The 12-month subscription is well worth the price. They have everything (plus more) you will ever need about your vehicle.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at FixYa.com!
SOURCE: How do I replace front shocks on a 2002 dodge
see chiltions manule for this its ezer than trying to explain allso get a alinement after it will re set your aline ment when you replace the shocks you will move everything on the frount end more up off the ground
SOURCE: how to replace sway bar end links on 2005 dakota
I just replaced 2 front stabilizer links and it was easy. You have to jack up both wheels make sure you take off both front tires makes it easier too work on take the top nut off on link by stabilizer bar first if you break it off dont worry its ok then take off bottom nut from the frame where the link goes thru put in new link tighten bottom nut first then tighten top nut dont over tighten top nut to much just enough that the threaded shaft is about a 1 1/4 inches above the nut do the same on the other side.
SOURCE: PLUG WIRE ORDER ON THE DISTRIBUTOR CAP FOR A 2001
From the 2001 Dodge Dakota maintenance manual.
Note the numbering of the 6 cylinders and the arrow indicating front of engine.
Firing order: 1-6-5-4-3-2, with distributor rotating clockwise.
