I would remove the PTO switch and have a Deere dealer test it. Also on the 500 series the PTO operates through the ignition control module which is under the dash, you can see it when you raise the hood. It is black and about 2" wide x 3" long and 1" thick.
This sounds like a seat micro switch problem, make sure the block connecter is fully home and the switch depresses when you sit in the seat, if all else fails replace the switch
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
