Razor Dune Runner 350 Go Cart Logo
D
David Hanna Posted on Apr 11, 2017
My Yamaha petrol buggy engine will not stop when I stop the cart. It will stop the engine with a little rave on the accelerator
PW50 yamaha. It starts, runs but cannot rave.
There could be a few different reasons why your kids PW50 Yamaha can start and run but cannot accelerate or "rave". Here are a few things you can try to troubleshoot the problem:
  1. Check the air filter: Make sure the air filter is clean and not clogged. A clogged air filter can restrict airflow to the engine, causing a lack of power.
  2. Check the carburetor: Make sure that the carburetor is clean and the jets are not clogged. A clogged carburetor can also restrict airflow to the engine, causing a lack of power.
  3. Check the spark plug: Make sure the spark plug is clean, dry and in good condition. A dirty or worn spark plug can cause a lack of power or no start.
  4. Check the fuel filter: Make sure the fuel filter is clean and not clogged. A clogged fuel filter can restrict fuel flow to the carburetor, causing a lack of power.
  5. Check the exhaust: Make sure the exhaust is not clogged, as this can restrict the engine's ability to breathe and cause a lack of power.
  6. Check the transmission oil: Make sure the transmission oil is at the correct level and not overfilled or contaminated.
  7. Check the drive chain: Make sure the drive chain is not loose or damaged.
It's important to note that these are general steps and the specific procedures may vary depending on the exact model and type of your PW50 Yamaha. It's recommended to consult the user manual or contact the manufacturer for the specific instructions and precautions for your bike. Additionally, it's best to seek professional help if you're not familiar with bike works.
2answers
I have a Patterson Eventer golf buggy, it goes about 12 inches and stops abruptly in forward or reverse. What's wrong?
Question edited for clarity.
Question moved to golf.
Solenoid. (electro-magnetically operated switch)
What are the symptoms of a bad solenoid in a golf cart? On an electric golf cart, the most common symptom is the solenoid is not delivering electricity to the controller when the vehicle's ignition is turned on. In normal operating conditions, the solenoid clicks on and off with the ignition switch. A failing solenoid will generally not click.
https://www.google.com/search?q=patterson+golf+buggy+solenoid
If it clicks, it is more likely to be the accelerator potentiometer, basically the variable gas pedal. Great resource in the link for Golf Cart woes.
https://www.golfcartsforsale.com/blog/5-common-electric-golf-cart-problems-solve/
Mar 18, 2022 • Golf
1helpful
My 2011 Yamaha gas cart will intermittently stop running. Trying to start results in starter turning but no acceleration. Waiting a day or less and cart returns to normal.
Check the engine stop relay is functioning. Depressing the accelerator engergizes the engine stop relay which opens the magneto (ignition module) kill shunt thereby allowing spark. This also energizes the motor generator thus spinning the engine in the selected direction. Further depressing the accelerator opens the carburetor to the point where fuel is allowed, engine accelerates and drives cart.
Could still be a fuel issue.
Apr 09, 2019 • Garden
Loud rattling sound when you accelerate faster in 2000 yamaha gulf cart
Sounds like pre-ignition knock. Not familiar with these engines, but be sure to use the recommended fuel.
1helpful
What type of oil does the yamaha golf buggy use ?
Mike, Yamalube 4-cycle oil or quality SAE 10w-30 motor oil, is the oil for use in your cart. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.yamahagolfcar.com/ownersmanualdownload
what kind of oil 2 use
What Type Oil and Amount is used in Yamaha G22 Max Gas Golf Cart
What type of oil does Yamaha golf cart take
Aug 07, 2016 • Golf
How do I find the model/year of my Yamaha Golf Cart with only the serial number?
The first three digits of the serial number are the model identification the remaining digits the unit production number
On my buggy there is a lable behind the drivers seat (lift the seat)indicating the model and year of manufacture
Dec 22, 2014 • Golf
Club electric golf carts
Resister coil pack....Look up Buggies Gone Wild. Tons of info.
Sep 08, 2013 • Golf
Oil and fuel blowing out through top of motor in yamaha golf cart 4 stroke engine
Engine got to much oil in it? Worn engine allowing fuel down into engine diluting the oil and raising the oil level? Blocked engine breather, pressurising the crankcase. Oil change and clean the breather. Worth a try
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
