SOURCE: Double sided printing with Toshiba Studio 3510c series
In the middle of the main screen (in copy mode) there is a big button called "simplex 1 to 1" or it may say "duplex". on the next screen you'll see different ways to do duplex copies. if you have a double sided original then select 2 to 2 / if you have 2 single side originals then select 1 to 2. Place originals in the document feeder and press start
SOURCE: want service manual of Toshiba photocopier model studio e-206
tradebit service manual link
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: Trying to print to a Toshiba copier (e-studio 207) from a Mac
this is it http://bit.ly/az02zD
SOURCE: I have Toshiba photocopier, Studio
If you are printig labels you MUST use the bypass tray on the right side of the copier. You mst specify heavy or card stock/label paper so it will fuse properly. I can't tell you why the tray does not work? But labels must be run thru the bypass.
Good Luck and Thank You for using Fixya.
SOURCE: how to reset error code f14 in the photocopy
guys please help me how reset error code F14 for Toshiba copier model no. 167
