Question about Welding Tools
Who makes the pro x one mig 200? - Welding Tools
  • Gabriel Brambila Nov 29, 2019
    Hello does any body know were I can find or buy parts for a proxone 200 mig welder. If you do can you send and info to. gbrambila1619@gmail.com
    Top Expert:
  • Welding Tools Master
  • 30,873 Answers
Anonymous
SOURCE:
What causes the 4 amp slo burning fuse to blow on a hobart beta mig 200
You are exceeding 4 amps? I have to believe this is a fuse for the control wiring and not the weld current or primary circuit. Likely you have a blown circuit board in the control area.
Sep 03, 2014 | Welding Tools
Can not find parts for Chicago electric 200 amp welder
You may not need to replace the board if the wire feed failed- most often it is an SCR or pair that has failed. Usually what is used is a 6 amp 600 volt SCR- you can go higher current and voltage for reliability. just make sure the heat sink is adequate or larger and heat transfer compound is used. Digi Key carries the "Teccor" SCR's other brands of the same or higher ratings will work.
Sep 16, 2012 | Welding Tools
Have a CT-200 Hobart Welder Getting high frequency but no current?
Sounds like the problem could be with your tig torch. Inside the tig torch you have a copper cable which carries your main welding current. If there is a break in the copper the high frequency is of such a high tension voltage that it can jump across the break in cable making it appear that your tig torch is fine. If you have a multimeter check continuity from one end of the torch to the other or try another tig torch.
Nov 06, 2011 | Hobart Handler 140 Mig Welder
I need a wiring diagrahm for a lincoln sa 200 can ya help?
I am a certified 6-g welder, and you can obtain the wiring prints through a welding supply company that sells lincoln products. Make sure you have the model number, as well as, the serial number. You will not find schematics posted online as this would be a rarely used post, so a dealer would be the fastest, and less time consuming effort.
Aug 11, 2011 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Need manual for 100E MK2
Hi:
Follow this link for clarke models pro-90, 100E and 150TE MIG,
http://www.mig-welding.co.uk/forum/files/clarke.pdf
If this help was useful, please vote.
Thank you
Feb 06, 2011 | Clarke Power Products Mig/Fluxcore Only 95...
Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Mar 19, 2010 | Welding Tools
Welding Tools Logo
1,110 people viewed this question
Top Welding Tools Experts
David Soto
David Soto
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
