Master
- Posted on Jul 24, 2009
Re: Lg tromm wm2277hs stops when it gets to the rinse...
Hi
- If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Check inlet valve operation
- If there is water in the unit:
- Check Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
- Check there is not a siphon problem
- Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
- Check all hoses for possible leaks
- Check pressure switch operation
- Check flow meter operation
Recent problem. Used to run fine.
