SOURCE: Amana SxS fridge not cooling or freezing
You have a sealed system problem. There is either a small leak or a restriction somewhere in the tubing. This isn't something you could've caused so don't worry about that. Unfortunately this isn't something you can fix yourself either. You require a certified refrigeration technician to fix this problem.
SOURCE: Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
SOURCE: I need a diagram for amana refrigerator model
My Amana refrigerator freezes everything. It has a bottom freezer.
