Is there grooves to tighten head trimmer on poulan weedeater
SOURCE: Poulan 17'' Gas Weedeater keeps dying!
Hello su2yak2:
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: how do iremove trimmer head weedeater fl20
It depends on your model. You can visit the PIVOTRIM website and they show how to install their head on most units which includes how to take your old one off. Their website is http://www.pivotrim.com
Otherwise you need to look at your operators manual or call the manufacturer.
SOURCE: I need to know how to load a two string trimmer
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
SOURCE: the pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
