How to connect bumper button to spool
SOURCE: replaceing string spool
if its the newer weedeater brand
All you need to do is grab the bump knob end and pull it straight off no turning
wind your line in the direction the arrows on the spool shows you
to put back insert line or lines into the holes and snap back on
be sure the spool is able to move up and down freely after install
SOURCE: Looking for a manual for a poulan / weedeater
Hello. here is the link to all of the poulans manuals. All free downloads
http://www.poulanpro.com/node4043.aspx?webecsearch=&%20O=true
please rate this answer as very helpful. thanks Joe
SOURCE: the pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
SOURCE: Removing spool on weedeater SG11 Electic
Pull on the tap head. Straight out. Hard. Here's the Weedeater manual. http://72.3.225.179/manuals/545117522e.pdf The spool should just pull out, its held in by 2 clips, royate it till it pops up then pull it out, with a wiggling motion, Grasp firmly and pull straight out....per tech support from 800 number on machine.
1. Disconnect the unit from the power
source.
2. Remove the spool by firmly pulling on the
tap button.
3. Clean entire surface of hub and spool.
4. Replace with a pre-wound spool or cut a
length of 30 feet of 0.065! (1.65 mm) diameter
Weed Eaterr brand line. Use of
heavier lines could overload and damage
unit.
WARNING: Never use wire, rope,
string, etc., which can break off and become a
dangerous missile.
5. Insert one end of the line about 1/2 inch (1
cm) into the small hole inside the spool.
6. Wind the line evenly and tightly onto the
spool. Wind in the direction of the arrow
found on the spool.
7. Push the line into the notch, leaving 3 to 5
inches (7 -- 12 cm) unwound.
8. Insert the line into the exit hole in the hub
as shown in the illustration.
9. Align the notch with the line exit hole.
10. Push the spool into the hub until it snaps
into place.
11. Pull on the line extending outside the hub
to release it from the notch; otherwise, the
unit will not function properly.
Thanks for choosing FixYa,
Kelly
