SOURCE: Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
SOURCE: govideo dvd player tells me all my discs are now "bad discs"
Open the dvd player up take a Q-tip dip it in alcohol clean the lenses . Then dry it off with a new dry Q-tip, put it back together start watching dvd's, Peter
SOURCE: vm9212n in-dash dvd player won't load cd's or
Must reset lazer lens manually. Most of the time this does the trick. hope this helps you
SOURCE: Advent DVD player in car won't eject DVD
Same problem for me, but believe it or not, we tapped on the DVD player with our knuckle (not bang on it) then hit eject and the disc came out.
SOURCE: LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Is your DVD player malfunctioning? If you're getting a no-disc error, you may need to clean the DVD player's laser pickup. The laser pickup is what reads DVD's and allows you to view them on your TV. If you need to clean the laser pickup lens on a DVD player, follow these simple steps.
Difficulty:
Moderate
Instructions
things you'll need:
