HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
Anonymous Posted on Nov 21, 2007
Does this Hp Pavilion zv5000 Laptop Batteries Fits for Hp Pavilion ze Series Laptop
There are many consumers search a hp pavilion ze series laptop replacement , I want to konow the Compaq HSTNN-DB02 battery for Hp pavilion zv5000 laptop power is compatible with it?
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 23, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
9506
Points
Hp pavilion zv5000 battery Compatible with Code:
  • Compaq 346970-001
  • Compaq Hstnn-db02
  • Compaq Hstnn-ub02
  • Compaq pp2100
  • Compaq pp2200
  • Hp 346970-001
  • Hp Compaq Hstnn-ib04
  • Hp dp390a
  • Hp dp399a
  • Hp Hstnn-db02
  • Hp Hstnn-ub02
  • so it is campatible with it~~
  • Add Your Answer
    tip
    Something about Replacement For HP Pavilion dv6000 Laptop Battery
    Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
    lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
    pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
    pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
    battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
    ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
    batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
    back guarantee and fast shipping on all of our products.
    on Apr 01, 2010 • Computers & Internet
    tip
    HP Pavilion dv9000 battery tips Your new HP Pavilion dv9000 laptop battery comes...
    DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Chemistry : Li-ion
    Voltage : 14.8V
    Capacity : 4400mAh
    Corlor : Black
    Original Price: US $85.63
    Special Price: US $65.63
    warranty.jpg * 1.One year warranty, 30 days Money Back.
    * 2.Brand new, 100% Q.C. of every battery.
    * 3. Highest quality Japanese battery cells.
    * 4. Guaranteed to meet original specifications.
    * 5. 100% secure and safe.
  • Shipping: Our laptop batteries are shipped by USPS.
    The battery have a good compatibility with many original laptop batteries for many laptops, even diffenent brands.
  • Descriptions of Hp DV9000 DV9700 DV9600 HSTNN-IB33 Battery 1. 100% new high quality Replacement DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Compatible Li-ion Batteries.
    2. This Hp DV9000 DV9700 DV9600 HSTNN-IB33 battery can be used for the other models and battery part No.
    3. 30-Day Money Back,1 Year Extended Warranty for Hp DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery.
    4. Great After-sales Service Department for laptop battery, fast respond to your request!
    5. Fast delivery if you order the Hp laptop battery.
    6. Need any assistance on DV9000 DV9700 DV9600 HSTNN-IB33 Laptop Battery, please feel free to email us!
  • on Jan 27, 2010 • Computers & Internet
    2helpful
    I attempted to upgrade the RAM on my HP Pavilion zv5000. (the one under the keyboard) when I tried to turn it on, there is just a blank screen. Any idea what the problem is? The laptop was installed...
    According to the link below you can do the upgrade. If is not working, make sure you have the memory seated correctly, then mix and match the memory and switch slots to find the problem memory. It may be incompatible with either the motherboard or the other memory sticks, or just a bad stick.
    http://www.insidemylaptop.com/upgrading-memory-hp-pavilion-zv5000-series-laptops/all-comments/
    2answers
    Is this hp pavilion dv1000 battery a cheap one?
    From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
    Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
    Rating: rate4.gif
    Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
    8800 mAh 11.10V C $ 79.69
    Availability: In stock
    Notes for charging Hp Pavilion dv1000 Series battery :
    1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
    2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
    3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
    4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
    5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
    6. It is normal for HP laptop battery to become warm during charging and discharging.
    7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
    4answers
    Can this HP Pavilion DV9000 laptop adapter fit for Compaq Presario V3000 laptop? I doult that HP Pavilion DV9000 laptop adapter on website:http://www.laptopbatteryshop.ca/hp-pavilion-dv9000-ac-adapter.htm...
    Have a look at the label on the bottom of the V3000 laptop and check the voltage and amps power rating of the laptop.
    If the DV9000 adapter has the same voltage and current rating (amps) or higher amp rating then it is suitable for the V3000 laptop, provided the power plug fits the V3000 power socket.
    1helpful
    2answers
    How about this Pavilion dv8000 Battery for HP Laptop Battery?
    You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
    http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
    http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
    2answers
    Ac adapter for hp pavilion ze 4900
    Go to spare parts shop you can resolve your problam with min price
    Top HP Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
