When I start the Fisher & Paykel 5.5kg Smart Drive Pride the cold water doesn't pull into the machine any more. It sounds like it's trying but keeps stopping after short bursts. The hot water pulls in no problem. After a few tries the machine stops and errors. The cold water tap has been checked by a plumber and is fine. The machine was working but I have moved home.
SOURCE: When filling my F&Paykel washer
You most likely have a smart water temp sensor on your machine. It makes sure you have the proper water temp to dissolve your detergent. Even when set to cold, it will add some hot water. It sounds like your machine is working properly. If you feel you are haveing a problem check the water temperatures in your owners manual and then check them with a thermomater in the washer. If they are not correct you may have a bad temperature sensor. Good Luck and I hope this helped. [email protected]
SOURCE: my fisher and paykel pride top load washing machine
Sounds like timer/controller is having problems--replace same.
SOURCE: Fisher and Paykel Washer smart drive 7.5kg starts and stops
the problem sounds like it is your out of balance switch is faulty. it is located under the control module at top of unit. 80 to 90% that is the problem. could also b rotor sensor or worst case, control module. if u r confident and have an electrical test meter reply back and i will help u more. please turn off power b4 u work on it.
SOURCE: We have a Fisher and Paykel toploader, smart drive
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
SOURCE: My fisher and paykel smartdrive 058 which has a
i am pretty sure its the main board, the easiest way to solve the problem is replace a the main board with a secondhand board, as well as obtaining a bag of spare parts, out a good working machine with faulty seals. You may have faulty seals if the machine is dormant for 3 years. I advise people never use washing powder in their washing machines, just use liquid detergent like Cold Power. the washing powder cakes up in the machine and when harden can be very abrasive and destroy the seals.
