Mine nokia
SOURCE: text messaging
try going into create message, choose new message, choose options, choose text set up and choose TAP english under primary text. then exit, thanks.
SOURCE: vibration for text message
I use an HTC Touch. Hopefully the menu should be the same in Touch HD as per the Touch. Try this..
Start -> Settings -> in the Personal tab, click Notifications -> u might see 2 tabs -> select Notifications tab again -> select an Event (here it is incoming SMS) -> below you'll see the Vibrate option -> tick on it to enable it -> Select OK to save.
Hope this helps, If so, rate me.. thanks - billa..
SOURCE: when i text the phone frezzes
Sounds like your battery or your sim card.
First, buy a cheap battery from Ebay and try it.
If that doesn't work, your SIM card may be faulty. Contact your carrier for a new one.
SOURCE: my blackberry curve starting texting weird, i
Hi
seems like you have a problem with the keypad. may be a water damage or moisture damge keypad near the track pad. thats make your keypad malfunctioning and it just keep sensing like you keep pressing a key while even if you are not using your phone. you can try remove your battery and put in a bowl of rice for 1 day or you can try drying your phone with air dryer. if its still the same issue then you may have to clean your keypad contact. thanks.
