SOURCE: Hoover F7425-900 How to attach hand held cleaner
There is a round door at the top/front of the clear duct on the hood of the unit. You insert the hose there and then connect the small solution hose to a valve that is located on the right side (if you are facing the machine) of the machine, just ahead of the rear wheel.
SOURCE: I have a "thunderstorm"type head
There is nothing like a repair kit for the hand held attachment unless you want to purchase a replacement hand held attachment. When the hand held segment begins to leak and "O" rings don't solve it then it is usually a sign that the hand held attachment is due to be replaced. After usage for a certain period the hose for the attachment as well as the aluminum used to make the hand held part begins to suffer from wear and tear and therefore the hose has multiple holes which brings about leakages and the aluminum also suffers from corrosion and begins to have cracks which also causes leakages.
Best option is to order a replacement kit for the hand held segment as that usually is the best repair kit available.
Hope this solution has been helpful?
