SOURCE: How to get into the Dos prompt at reboot for the IBM ThinkPad 2645?
Vince,
First of all, What operating system do you have on this machine?
If it's Win98, you can get DOS.
If it's WinXP, you will have to make a bootable CD to get into the DOS prompt.
Check out this link :
http://www.bootdisk.com/bootdisk.htm
You can also get into the setup from CD, by changing the boot sequence from BIOS. (If the installation CD that you have is a bootable CD)
Hope this helps.
Thanks & Good luck!
SOURCE: I am trying to do
that means that file is not an executable file or not an application. try typing dir *.exe and then run the file that displays. since those files that displayed are the executable files.
SOURCE: TOSHIBA SATELLITE PROA200 NOT REBOOTING AFTER A PARTION
You will have to get into the bios (tap F2 after you turn the laptop on) and insure that the first boot device is the optical drive (cdrom), then you should be able to utilize the recovery dvd.
SOURCE: How can I run a dos app without using a command prompt console?
Hi there.
Take a look at this site for all your DOS programs and software >>>
http://www.opus.co.tt/dave/
Good luck and thanks for using FixYa!!
SOURCE: my iphone 3G does not starting up it simply shows the apple logo
U PLS do as i say ..............Open iTunes and connect the iPhone to your Mac or PC
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black like this:
NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
You will need a operating
system disk or a repair disk to fix it. Insert it in the drive then boot
from it. You want to get to a dos command prompt (black screen with white
lettering) and type the following commands. Press ENTER after each
command.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the dos
command prompt and run the check disk utility.
To
run the check disk utility you will need a repair disc or a operating system
disc. Put the disc in the cd drive and boot from it. You want to
get to the Dos Command Prompt (Black screen with white letters) and type the
following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the
percentages going from high to low, this is normal. Let it run to
completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.
Try doing a Repair Install that way you don't loose your data, documents,
music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when
the options appear.
In Vista and Windows 7 you want to get to the recovery
console and look down at the bottom of the window for the Dos Command.
To run the check disk utility you will need a repair disc or
a operating system disc. Put the disc in the cd drive and boot from
it. You want to get to the Dos Command Prompt (Black screen with white
letters) and type the following command: chkdsk /r
the options appear.
the options appear.
1. Check your BIOS to be sure your computer will boot from a CD.
Enter the BIOS setup by pressing the "Delete" or F2 or "F12"
key, or as directed at the startup screen, immediately after booting. Set the
first boot device to "CDROM" or "DVDROM" instead of
"hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive
and restart the computer. When prompted, choose to start from the MS-DOS
command prompt with CD support. The MS-DOS command prompt will appear in a
moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt
and pressing enter. You don't have to run SMARTDRIVE, but copying the files
will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the
directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup.
The installation program will copy files to your computer and then display a
message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will
start again and check that your hard drive format is compatible with Windows
XP. If not, it will guide you through partitioning and formatting the drive and
then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
