The old water valve was leaking,where the tube for the ice maker was. Took the new valve back, and tested fine. Put it back on, still not working. Have put water down through the tube. Goes through fine. Could it be an electrical problem. model is westinghouse RS643V
SOURCE: Ice maker not working
It's possible that the tube that supplies water to the ice maker is blocked with ice (freezer temp. too cold) and not allowing water to get to the Ice tray.
You can squeeze the tube to see if it's iced, and if so you can melt the ice with a blow dryer and adjust your freezer temp. to the manufacturer's suggested setting and work from there.
I have seen this happen, but there are other problems such as just a broken ice maker too.
Good luck.
SOURCE: Ice maker won't make ice
It sounds like the fill tube coming through the freezer wall is frozen shut. Need to carefully take a hair dryer to it then recheck with wire swap. If you turn i/m off for a couple hours then back on you should be able to watch the fingers go around. If so you module should be good.
SOURCE: Water tube extension
it sounds like the water inlet valve is bad. if it slowly leaks it will cause the water to freeze inside the inlet tube extension blocking water from entering the icemaker and it could leak around the extension tube. after freezing solid the tube may have a crack in it as well. so replace the water valve and take out the inlet tube and extension tube and inspect it for cracks and make sure they mate properly (you can glue them if you want but it might make it harder to clean out if you have the same problem again). a clamp or tie strap may help.
SOURCE: GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
If your ice maker has stopped producing ice completely, check these, in this order:
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
