Https://youtu.be/TfozQrwGWlg How to use the Buttons on Neff Microwave Combination Oven with Two Guys...
SOURCE: Power Problems on NEFF H7871 Combi Microwave
I currently have the same problem and Neff can't fix it. Problem is a short on one of the boards. Currently the required replacement boards are not available.
SOURCE: Replacing lightbulb in Sharp R953M combi microwave oven
most microwave ovens built in the last 20 years do not have an
access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
Then pull upward and backward on the sleeve to disengage it
from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
are not unscrewable from the socket, but the socket and bulb
come as an assembly.
SOURCE: I have a Neff Microwave/Oven/Grill
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
SOURCE: clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Noisy Fan in Neff Combi Microwave/Oven. B6774.0gb
yes you can fix it yourself it is a cooling fan in the top it is round metal fan quite small venting waste fumes from cavity when grilling etc need to remove top panel and 3 screws to remove it is a push in fit.
