I would say pull it apart again and fiddle about with it a bit paying some attention to that spring loaded ring that's causing you grief. I don't have one here to look at but I know I've seen that problem before and it's something to do with that ring underneath needing to be turned to a certain position so that it engages properly. There are some notches in it that need to be in a p[articular position. We never saw that version for too long, the following model had a plastic beaker without all that rubbish on the bottom.
SOURCE: Black and Decker Blender Model Number 675 Replacement Parts - Collar
http://www.thegourmetdepotco.com/store/store_partaccess_index.asp?ManufacturerID=5&CategoryID=1&gclid=CICJ0pWm0ZMCFQnIsgodnkhAhg
SOURCE: my blender's jar is broken, i want a new one
You might need to order one from the UK and pay delivery charges? I am based in the UK and it is tricky finding this part, but I think possible. I smashed my blender measuring jug this morning and I hope I can get a new one at [email protected] - just placed an order. You don't mention a model of yours but the one I found is compatible with several makes - check out this link http://www.viewpointdirect.co.uk/philips-measuring-jug---for-use-with-hand-blenders-573-p.asp. They deliver worldwide for a reasonably high charge. Else there are some other jugs you can find, without pictures though, which might be compatible with your make, at http://www.buyspares.co.uk. Good luck!
SOURCE: Locking the jar on the base Oster Fusion 600W Blender
Here is the user manual for the Oster Fusion:
http://www.osterfusion.com/Manuals/MANUALS/BRLY07-Z00-000_43_29190737.PDF
It looks like you line up the threads, place the base on, and twist to tighten.
-Tha Mp3 Doctor
