SOURCE: I need to remove the float bowl from a Troy-Bilt
on the bottom of bowl is a 3/8 nut remove that and gently tap the side of bowl ,there is a rubber gasket on top of bowl and it will stick
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
SOURCE: Describe your Troy Troy-Bilt® Briggs and
I Have a MTB chipper shredder, model 24A-464B062 (sometime between 2000 and 2002), which appears to be a Lowes model. In my case, I left the shredded blade on and backed off the main bolt holding on the impeller so that about 1/4 of an inch of threads were showing. I then attached my harbor freight automotive pulley puller (Pittsburgh - item#66868), with its shaft pushing on the head of the main bolt and its arms hooked onto the shredder blade. I then torqued the puller hard until the shredder blade was bending pretty good. The impeller did not come off. I then used a cold chisel and a hammer to pound around the center cylinder of the impeller (there are two small spots where this can be reached). Still the impeller did not come off. I then used my plumbing torch (with MAPP gas), to heat up the center of the impeller, for about 5 minutes. Still the impeller did not come off. So I returned to the cold chisel and hammer, and after a few hits, the impeller popped loose. I removed the automotive pulley puller (be careful, it is hot), and then the main bolt, and the impeller came right off. After inspection, I noticed that there is no key and that the impeller is attached by a press fit taper. So it looks like what I did is most likely what everybody else would have to do for my model.
