Pull the inlet hose off the drain pump to check for clogs. If this goes into a garbage disposal back flush the pump with a pressurized water source will also work. This means removing the unit from the house of course. Do you hear the drain pump running after a cycle completes?
Testimonial: "Thank you, will try that."
Thank you very much. Your help is much appreciated. I think there was air in the water inlet hose. It's now working. Thanks again.
