Changing Fixya password.
SOURCE: I cant get into the settings for my Dynamode wireless cable router
Reset the router to factory default, this way you can put in a new password and WEP.
**On the vast majority of routers the reset button is found either on the back plate or on the underside of the router. The reset button is on the rear of your router
**The reset button is YES! a TINY tiny little hole no bigger than a pencil point or full stop. You can easily miss it, to perform a reset you will need a paper clip or pin.
TO RESET, using the paper clip straightened out, push the end of the paper clip into the tiny hole, and push it firmly until you feel a resistance. hold the paper clip, & push & hold in the reset button for 20 -25 seconds (with the power turned on). after you have done this power off and power back on the router.
Now! the router should have all its original factory default settings, as if you just took it out of the box for the first time:so you should be able to get to the setup page and set the WEP encryption.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: i forgot the password to my email and dont remember my alternate
Try searching your email address on www.spokeo.com or your name and/or email address on www.peekyou.com. They might be able to come up with your alternate email address, and hopefully it is a yahoo one, or another service that will let you recover the password with security questions. www.pipl.com also might have your alternate id on it.
Another thought, is if you use mozilla, your password very well could be saved, you can find that under the tools. If it saved you passwords, you will be able to view the whole list of them.
SOURCE: i cannot remember my privacy lock how can i create
if u cant remember ur passlock, it cant be changed. u will hav 2 flash ur mobile by a mobile technician, 2 reset it 2 the factory settings
SOURCE: i forgot my sandisk 8GB USB 2.0 Flash Drive 's
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
SOURCE: I HAVE AN LG INCITE AND I FORGOT THE WINDOWS
You don't have to get it to factory setting as this will wipe all partition data. The fact is you are able to rely on this password recovery tool to reset your forgotten Windows Administrator login password easily. After that re-start your computer and you'll access your PC as normal.
