My Amana side by side DRS2660bw Refrigerator is not cooling and both freezer and Refrigerator compartments show 30 F
SOURCE: Hot point side by side electronics not operating damper
See if you have some paperwork on how to test, etc. located in a plastic bag taped up to the underside of the fridge. Pull the front vent cover off and you should see (feel) a bag taped up there with the test paperwork in it. If you don't have it let us know and maybe I can email it to you.
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
HI,
The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
thanks,
SOURCE: AGE AND OTHER INFO ON SIDE BY SIDE AMANA
The C J at the end of the serial # indicated :
C = 2003
J = May
This machine was made by Maycor cop. Now is Owned by Whirlpool.
SOURCE: I have an Amana Side
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Carl has the compressor been running continuous? Also between the freezer and fresh food compartment you will have a damper control hiding behind the controls. Some have a lever arm that helps adjust the damper to reduce or increase airflow from freezer and it is possible that the damper has become stuck wide open or the lever arm that when you slide the arm to adjust damper has come loose from the damper. Click Here for large photo=> Amana ATB2132ARQ Controls If your thermostat will not turn off then we may have a problem with=> 63001358 Thermostat Control as it could be bad and out of calibration. This is an interesting problem and would like to know what you find and resolve the problem. If this solution is helpful please rate, if not ask until I can help you fix this. Freezing fresh food is not good so I will be here to assist you, Thanks, Sea Breeze
The problem has to be in the damper control inside the refrigerator section.
Disconnect the refrigerator from power and remove the food from the top shelf. The damper control is in the box near the top of the refrigerator section behind the temperature control knob.
Remove the knob and cover until you can access the damper control. You can prop the damper control open with a pencil or something to make the refrigerator work until you get a part if you need to. Here is the part you need.
