Consequently, refilling your Aficio cartridges with aftermarket toner can save your business ... may have to replace the smart chip so the printer page count will reset and allow you to print. ... Many toner refill kits ship with the needed smart chip
this printer cartridge has an ID chip. If you want to refill toner cartridge, you will have to by toner and you can buy chip or if you have chip reseter, then reset the chip. It works fine. I use toner from supplier named "Uninet".
P.S. This cartridge is not easy for recycling
Before we start first make sure the machine is turn-off for our safety process.
Question: 1. Did you try to change the other toner cartridge?
Step 2:
Possible cause and way to check Toner Change Problem & No more Printing: - Dirty Sensor (check all the sensor) - Dirty Glass (check all the glass) - The cartridge is not properly installed - Full Waste Toner section - The corona wire is dirty or broken (Inside the cartridge) - The transfer Unit is dirty or broken (Inside the cartridge) - Broken gear motor connected into the drum section - If they have developer include in this model try to check it and repalce if empty - Broken Fuser Film - Broken Fuser Lamp - Broken or dirty Cleaning Blade Section - Check if they have also chips include in the cartridge
Step 3:
Check all the possible cause and try to clean or replace the parts if broken.
In order for your printer to read the cartridge as full the chip on the toner will need to be replaced/reset. Sadly these cartridges are unable to physically check toner levels and rely upon counting pages/page coverage to estimate.
WE HAVE RICOH PRINTER SP 1100SF & REPLACED CARTRIDGE WITH NEW RECYCLED BLACK TONNER CARTRIDGE FROM POWER POINT, BUT UNABLE TO PRINT AS CHIP GIVEN IS NOT ACCEPTED BY PRINTER. TRIED 3 DIFFERENT CHIPS STILL PROBLEM PERSISTS. WHAT MAY BE THE RESEASON AND SOLUTION
SC 680 BCU/ MUSIC communication error
After the engine CPU sends a message, the Music CPU does not respond within five seconds three consecutive times.
• Toner cartridge memory chip loose connection
• Memory chip problem
• Memory chip cable wiring problem
1. Turn the main switch off and on.
2. Check if the toner cartridge is installed correctly.
3. Replace the toner cartridge.
4. Check if the harnesses are not damaged.
5. Replace the BCU.
I believe you will need to purchase and install a reset chip. You can find them for the Ricoh C410 here at www.cfriends.com (that links straight tothe ricoh page - but if you need to search, type in "c410" into the search field on their site).
