Are you sure you're waiting long enough? The way it works is that it shuts the auger on and off for designated times. You have to wait the designated interval (up to 135 seconds of inactivity). You can adjust this on some models as shown here: http://tipsforbbq.com/Definition/Traeger-P-Setting
SOURCE: i have about 1996 country flame pellet stove. when
Need a new auger motor. They have beefed up to a bigger stronger motor
SOURCE: The pellet auger on my traeger doesn't feed pellets
Call Treager direct
They have a great customer service dept and if you have an issue with a motor or control board they are really good about sending replacements
800-372-3437
If this helps please leave a comment
SOURCE: I turned off my grill
Whenever you finish using your Traeger it is always best to lift the lid and turn the controller down to the smoke setting and allow the temp to drop for a few minutes. This will also slow down the delivery of fresh pellets into your firepot thus starving the fire of fuel.Once the temp drops below 200 deg F than shut off the controller. If you have any wind blowing remove your Traeger out of the draft of the wind and the fire will go out on its own.
SOURCE: My Traeger (BBQ070) will feed the pellets, but there is no ignition to burn the pellets.
Be sure check the fuse behind the control board when pellets auger in but do not ignite.
I changed the biscuits on mine, and it got hotter
