This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
SOURCE: What is error code 5000 for sharp mx-3100n
HI,
this will help you out...
http://www.afoffice.com/sharperrorcodes.htm
thank you,
vijay(vote for me)
Testimonial: "Many thanks"
SOURCE: Sharp MX 3100n showing code H5-01 , what is it,how
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
SOURCE: our sharp mx-m450N gives us error code u2-11. what
EEPROM read/write error (serial communication error)
SOURCE: Our sharp MX-3100n printer is
Apparently your machine is set to stop when the supply counters trigger a maintenance code. You can type # * C * and go into Sim 26-38 and bypass this.
VC means your cyan developer has reached its' rated life of 60,000 copies and needs to be changed. Your yellow and magenta developer which are usually changed at the same time as the cyan have also reached their end of life (VM, VY) and so all 3 will need to be changed (not black, your VK code will come up at 100,000).
You will need the color developer kit and the seals and filter. Sim 24 resets the counters and sim 25 resets the toner-developer mix ratio (this is MANDATORY or your new developer will be ruined, you must run the copier with a door open and only close it when you are ready to set the mix).
There's also various color calibrations after this you can get from a service manual. DO NOT run old developer through your machine, it will eventually lose its' magnetic properties and be carried through the copier sandblasting everything in its' path.
SOURCE: SHARP MX-3100N CODE E7-06
MFP -Image data decoder error
Try to clear code. enter sim with program key- asterisk*-clear key- asterisk*(P-*-C-*) enter sim 14 print key execute yes clear all machine will reset. if code comes back it is not just not a fluke and you may have another issue.
