you canot reverse the handles on this model. There are no predrilled holes or covering plugs on the opposite side. The model number ends in an "l" signifying left hinges. The companion model ends in an "r" with hinges on the right. These fridges were designed so you could purchase them as a pair seting them side by side.
I checked the owners manual - found that two small screws holding the bracket on came loose - reattached the screws, then de-attached the handel from left side so entire handle was off. Then slid handle on both brackets left to right until it clicked on.
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle. 1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door. 2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used:HANDLE, DOOR (WHT)Level of difficulty:
Difficult
Time to do repair:
30 - 60 mins
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
I just had the same problem with the same fridge. When I removed the inside panel in the freezer, I found that the cooling/circulation fan had fallen due to the mounting screws having rusted off. I removed the fan housing to get the screw ends out from the back side and remounted the fan with new screws. The fridge and freezer both work fine now and I'm assuming it will for many more years until it happens again.
At both ends and actually inside the ends of the handle, are small metal brackets that are attached to the door face by a single screw. You access the screws by pulling the plastic plugs, using a very small and thin flat bladed screw driver. My handle was loose but hadn't come off on it's own. But I couldn't get the handle to fully tighten. My fix was to wrap each end bracket with a couple layers of electrical tape (not covering the screw hole) and reattached the handle. It is now very tight, as it should be.
