Mitsubishi LT46164 has a known issue developing on the main board that causes what you describe (and other things):
http://www.coppelltvrepair.com/p/1635/repair-service-for-mitsubishi-main-board-934c374002-causing-dead-tv-blinking-loop-no-hdmi-no-audio-etc-problems
SOURCE: HDTV connection on TV is not HDMI
The port is called a DVI input. You can find a HDMI to DVI adapter at Circuit City, Best Buy, Ultimate etc..........
SOURCE: No sound through HDMI port on rear of tv
You could replace the HDMI port on the TV, it's no different than changing a USB port card in your computer. But, finding the replacement HDMI port card for your TV can be tough. Try shopjimmy.com for parts.
SOURCE: HDMI port not working.
If your getting it to work on the regular RCA Jacks then it is your dvr box problem. I would contact your cable provider.
SOURCE: Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
SOURCE: HDMI ports will not work
Unplug the tv,satalite box and playstation 3,replug all the devices about an hour later.Go in ur tv menu,goto PICTURE,go down to reset the Tv Tuner board,will reset the tv Tuner board will reset it back to factory setting.Than still have the same problems.The tv Tuner board it dead,require the Tv tuner replacement.
