SOURCE: Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
SOURCE: Is there a way to remove the drawer in the bottom freezer?
Pull the drawer all the way out until it stops. Then lift the front of the freezer drawer (a couple of inches), and pull out further (4-6"). The front will then lower to the floor. Lift the back of the drawer upward and slid the entire drawer forward. You may want to protect your floor. I did the above with the freezer drawer full and scratched my floor a little...
SOURCE: How do you remove the sliding freezer drawers?
1 Open drawer to the fully out position. 2 Remove upper and lower baskets. 3 Remove screws one in each rail marked on side of rail. 4 Lift the front of the drawer up to remove the drawer. 5 Set the drawer on a soft surface to prevent scratching the
finish. If you have other questions please ask, Thanks Sea Breeze
In that photo is part 12 and that is the defrost timer part number Click Here=> 67001036 Without opening panel look for a small opening or plastic plug remove plug and place a screwdriver in hole and turn slowly clockwise to see when compressor and fans stop running. That position should create about 25 minute defrost and it does this every 8 hours. Now if fans are not running or when checking the compressor unplug for a few and pull away from wall. Remove lower cover on rear bottom and then feel top of compressor and can you tell me if too hot to keep there, warm or nothing different? Replug power and carefully feel for compressor running. I will be able to place links in this message one time so please let me know if I can help more.
Click Here=> Sea Breeze If you have
any questions please ask, Thanks, Sea Breeze
