SOURCE: dvd stuck in advent 10"
Sienna Minivan with a DVD entertainment system - rule nr 1 - Recorded DVDs would play but not eject, and then jam the system. It will require disassembly of the housing to reset power to eject.
SOURCE: LG GSA 4163B DVD±RW dvd playing but no sound
Install k-lite codec pack ,you are missing codec. Some recommend vlc player.
SOURCE: I have a Advent ADV35 mobile DVD player. When
while the power is still on find the reset butoon (usally behind faceplate) once found push and hold reset button aprox 10sec (make sure you do this with something that is non metallic) see if that helps hope it does
SOURCE: My car Advent DVD player has a blue screen and
Blue screen means no input source. Check for loose connections. Run a commercial disc cleaner through it to clean the laser lens. Still nothing? then replace the optical drive in the unit cause it has given up the ghost.
