Question about Pride New Mobility Legend 4 Wheel Scooter
Pride Mobility Legend XL will not go forward or reverse. When I turn the key to the on position and try to go forward or reverse, a green light in the dashboard starts flashing rapidly.
The flashing green light does not stop until I turn the key to the off position. The batteries are fully charged, wiring connections look clean, I have tried it in the locked position as well as the unlocked position, the horn works, the indicators work, the headlight works. It is not plugged into the charger. Any help would be truly appreciated. Thank you.
Anonymous
SOURCE:
gewiz
Rob Hill
  • 1414 Answers
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
Posted on Jun 13, 2009
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Posted on Jun 18, 2009
oregoon
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
gewiz
Rob Hill
  • 1414 Answers
SOURCE: Batteries fully charged on pride legend fuses,
Hi ,you need to check whether there are any fuses under the seat,
Does the horn work ? , do the power tiller ? the display showing how much the battery is charged
Regards
GeWiz
Posted on Aug 12, 2009
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: Battery fully charged chair levers engaged to
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
Posted on Dec 27, 2010
I have a Pride Sundancer that will usually go forward but not reverse. Green light flashed 3 then 5 blinks. What is the problem
Hi charge batteries & get them load tested ..U can buy a BATTERY LOAD TESTER of E/BAY cost aprox $36 this will give U an accurate reading on there condition,.3 flashe's unplug charger & turn key of & back on ..5 flashe's remove key push freewheel lever into freewheel & back into drive put key back & try it . Cheers
Nov 30, 2016 | Pride Health & Beauty
HOW MANY OHMS SHOULD GO THRU PRIDE CELEBRITY X CONTROL ?
I have a Pride Legend XL. I tried to get the wiring diagram, but
Pride USA would not give it to me.
They told me to call the dealer instead. I had a problem with reverse throttle creep, where the brake would not engage and it kept rolling back on me.
Had to call the local dealer to do the intial trouble shooting
(who knew exactly what the problem was) to the forward reverse throttle control pot.. I was able to order the throttle pot and replace it myself.
The problem is that Pride uses some potted modules in the tiller
and the control area, although you can find pretty much
all the parts for Pride from monsterscooterparts.com,
they don't have the wiring diagram for mine either.
I am disappointed in Pride, who want to keep their
service manual with the wiring diagram a big secret from
the owners and only the dealers have it.
Oct 19, 2014 | Pride Health & Beauty
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
May 24, 2014 | Pride Mobility Products Pride Celebrity XL...
Pride GoGo Ultra X battery meter needle
you could have a bad throttle pot o speed pot possibly a key switch problem aswell. Hi I a Phillip the "DFW Mobility Specialist"send me a email at dfwmobilityspecialist@yahoo.com if you live in or near the Dallas Fort Worth area.
Apr 10, 2013 | Pride Mobility Products GoGo Ultra X...
The kids drove my Pride Legend XL through a puddle. I doesn't go anymore. I need a technical Reference Manual with schematics. I could fix it myself or......? Batteries are fully charged. No...
I had a similar problem with my Pride Legend XL when I drove it
through a puddle accidently and some water splashed up underneath
the motor controller. It would buck or go then stoo without any warning
as the electric brake was applied. Had to take the seat off and use a
hair dryer on the controller connections to dry them out. It doesn't
seem to take much water to make these inoperative. After thoroughly
dried out with a hair dryer..no more problems like that with it.
Oct 27, 2011 | Pride Mobility Products Pride Legend XL -...
My scooter when I press the throttle to go forward it like breaks or stops. I have a Legend XL. It goes OK in reverse but, when you press to go forward it breaks like bad gas.
hi i hsave a pride legend classic mobility scooter it will run ok for a few yards then suddenly stop but if u wait for a bit it will go again whats the problem thanks
Mar 02, 2010 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
My Pride Legend 3 wheel scooter will not go forward. It goes in reverse with no problem. Help
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
Feb 13, 2010 | Pride Mobility Victory 3 Wheel Electric...
I bumped into a wall and now the steering column will not adjust
I really need to see a photo of this problem, a close up picture of where you think it broken
Apr 06, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Pride New Mobility Legend 4 Wheel Scooter Logo
457 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
