SOURCE: washer fills up but then stops.opening and closing the lid starts it again and finishes the cycle
timer controls needs replacing
SOURCE: I have a Maytag Neptune top load washer touch
I no longer need a solution. My son took the lock off and put it back on, and the machine started working again.
Thanks you so much.
SOURCE: Lights keep cycling madly, can't change the
I feel you have a Control Board issue.
I have seen this problem here and on other forums with our FAV6800A machine.
I would swap out the Control Board and see if that would take care of the issue.
If you were near 19344 area I would offer a up a Control Board to try. I have three working spares.
I'm an owner like you, I buy these used and repair the FAV6800A for resale. Ebay is a good source for parts. All three Control Boards came form ebay for penies on the dollar and work....been lucky to date.
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
