SOURCE: Crosley Washing Machine leaking
cHECK PUMP AND ENSURE THE PROP CAN SPIN AND THERE IS NO **** IN THERE IF THERE IS CLEAR IT
Thank you for your post, derek dion!
From the information you have provided you need to know how to access the drain pump on your Crosley washer. I was unable to locate a step by step instruction sheet on how to access the drain pump. From your parts manual you would need to remove the front panel and it is located directly under the drum. If you are having trouble locating it or removing the front panel I would recommend contacting a professional technician for proper disassembly and repair. Best of luck! -OOS
