Aircrafts Logo
H
Harold Lilly Posted on Jan 04, 2017
Defects and return systems to an airworthy conditions in aircraft fluid function?
Joe Austin
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Jan 04, 2018
Joe Austin
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
773
Points
12
Your question does not make sense. You are mixing terms. Maybe I can help if I understand your question better.
How to know if the aircraft is airworthy?
From a pilot's point of view, every aircraft comes from the factory with a checklist of things to look at specifically before every flight to ensure airworthiness. It's generally called a walk-around inspection, checking flight controls for security and condition, tire condition, engine for obvious problems. propeller, fuel and oil quantities. and many other things. The walk around also includes checking to ensure all required paperwork is there including weight and balance, airworthiness certificate, aircraft registration, operator's manual. etc. I would also check the log book to verify the transponder check was done within the past 24 months and the annual or 100 hour inspection is current. From an A&P mechanic point of view much the same applies, however I would look much closer at the maintenance logs for engine and airframe.
Jan 04, 2017 • Aircrafts
2answers
Why does the USA uses companies like Boeing and Lockheed to make there military aircraft and other military eqipment?
The cost in designing, developing, and testing an aircraft is staggering!!! Defense contractors as those you mention have extremely strict regulations to follow regarding export control and no equipment is sold to a foreign government without the express approval of the US gov't.
1helpful
2answers
Airplane question?
That would be the ground prox system on the aircraft it lets the flight crew know how far they are above the ground during an approach to the landing runway.
How can pilots find the aircraft carrier when their 200 or 300 miles from it. I can never figure this out.?
James,
There are navigation and softwares inside the cockpit so pilot can find easily as well as air traffic controllers will guide them so they can easily land there....
with regards,
jaijith
Top Aircrafts Experts
ADMIN Andrew
ADMIN Andrew
Kolbrun...
ADMIN Eric
ADMIN Eric
Are you an Aircraft Expert? Answer questions, earn points and help others
