The chain came off and I do not know exactly how to re-attach it and tension it to keep it from coming off again.
Could you please attach a link to the manual by return e-mail?
Thank You,
Gary Johnson
Here is a link to the instructions to replace a chain and tension it properly... http://12.153.20.74/manuals/113556-01A.pdf. Here is a link to the owner's manual you requested...
http://12.153.20.74/manuals/108539-01L.PDF . If your chain is new they will stretch quickly during their break-in period and will have to be tightened frequently. Once they have been used for a while they will not have to be tightened as often. Sometime if you also need stech and fall off quite a bit. If you need a replacement chain (8SC), you can find them oline at www.masterparts.net. Also, if the guide bar nuts are not tightened securely the bar will not remain in adjustment. Make sure that the guide bar bolts are tightened. I hope this helps!
