When we try it, we hear a clunk and the humming that sounds like it should be, but nothing comes out. The icemaker works fine. We're getting water as far as the joint at the bottom of the door.
SOURCE: Amana refrigerator water dispenser not working
No you don't. You have two water solenoids in the back. One for ice, one for water. Pull line off water solenoid and blow into it. For more help go live chat.
SOURCE: my kenmore refrigerator 106.56166500 quit
The line inside the freezer door is frozen . Turn the temp in the freezer , to warmer for a few days , and it should thaw . A dispensor heater is available , pt # WR49X10173 . Instructions come with the part .
SOURCE: GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
