SOURCE: Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The
motor isn't on full throttle.
2. The blade is upside down.
3. The grass is
too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
SOURCE: my lawn mower will not stay started
Since it starts, it doesn't sound like an electrical problem, it sounds like it runs out of air. To test this, remove the air filter, start it and see if it stays running. If so, replace the air filter.
It could also be varnish or sludge in the carb bowl. This is best serviced by a technician if you have little mechanical prowess.
After sitting for 3 years, I would at minimum do all of this before I expected it to run ok:
If the above did not work I would drop the carb bowl and clean it, then add one ounce of carb cleaner to a full tank, and let it run (roughly if necessary) through the engine.
After sitting 3 years I would also replace the fuel line itself!
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
SOURCE: Cant remove blade on lawn mower
Follow directions. See if this works;
Blade Maintenance
Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
SOURCE: how do we service the blade / brake clutch
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
