Coffee beans not going into the grinder, bean grinder motor is working though
Remove the brew unit and open the little door of the coffee chamber that is above the brew unit. Use a broken/folded wooden skewer stick to clean out the channel between the grinder and the coffee chamber. You will have to feel the channel, as there is no way to see what you are doing. Just bend/break the skewer to a right angle and slide it into the chamber with the pointed end to the right, toward the grinder, then wiggle it until you feel it enter the channel. Then wiggle it some more to loosen the coffee grounds that may be causing the blockage. Be careful not to damage the sensor flap that is just above inside the door to the coffee chamber.
No help with this
