Oh oh seems like you punctured the freon line and now ur compressor will be out of freon and you will need to also replace the part you punctured, the line that is?
that liquid is what keeps ur frige cold!
So how much do you think this will be what do I do exactly
as for the cost well most tec guys will charge an arm and a leg for a simple job. but the replacing of the tubing which was damaged may be somewhat difficult. depending where it was damaged there may be some kind of sealer u can purchase to fill the puncture but Im not sure as I never tried that.u can call an appliance place and ask them
SOURCE: Maytag MSD2454GR
Im going to be honest with you,to me it sounds like 1 of 2 problems,
either you need a re gas on your fridge or you need a compressor.
Let a repair man take a look for you just to tell you what it is..
Sorry for this news.
Wouter.
SOURCE: frigidaire side by side freezer not freezing but
you may have defrost problem check see if you have frost build up in the freezer back wall
SOURCE: freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
