Question about Canon PIXMA MP470 All-in-One Printer
How to remove printer head on canon pixma mp470
Anonymous
SOURCE:
Anonymous
  • 135 Answers
SOURCE: lost install CD for Canon PIXMA MP160
This link is to the drivers for the MP160, you can then download the drivers to your pc and run them with a CD http://rapidshare.com/files/115660111/canonmp160.exe
Posted on May 17, 2008
Anonymous
SOURCE: canon pixma mp470 printer error
canon pixma mp470 printer error u051
Posted on Oct 18, 2008
vegakitten20
Juanita Vega
  • 685 Answers
SOURCE: installed new ink & it says "Print head is not installed" -
try to unplug it and plug it back in
Posted on Mar 04, 2009
Joed911
JDTec
  • 4338 Answers
SOURCE: Print Head Problem
Perform these steps and reset the EEPROM:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 20, 2009
Anonymous
SOURCE: Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Posted on Feb 01, 2010
How to fix Canon Pixma MP470 printer that does not feed paper properly to print from Windows PC
Open up the printer and see if there is a small piece of paper that is interfering with the paper path. You may have to use a flashlight to see it.
Sep 10, 2014 | Canon PIXMA MP470 All-in-One Printer
Canon mp470 can't accept refilled cartridge
Canon mp470 is an excellent printer.I will always recommend using original catridges in your printer.Refilled catridges are not accepted by the manufacturers.Let me tell you i used to work for HP in the beginning of my carreer. I have seen that HP refused to accept refilled catriges. hence i would reccommend you take a cotton cloth ,remove the catridges from the printer.Clean the print heads using that cotton cloth n then reinstall the catridges back .......
Lets see if this resolves the issue
With Regards,
AsitRoutRocks
Dec 17, 2013 | Canon PIXMA MP470 All-in-One Printer
ERROR 5100
Follow the steps mentioned below:
  • Press ON/OFF switch to reset the multifunction device
  • Remove Packing Material / paper jam MP470
  • Reseat ink cartridge MP470
  • The MP470 may require repair
  • You can get the detailed troubleshooting steps from the link below:
    http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp470#ServiceAndSupport
    Jun 24, 2011 | Canon PIXMA MP470 All-in-One Printer
    How to install printhead in canon mp470 printer
    There are 2 ink cartridges that came with the printer (PG-40 and CL-31). These are the consumables that are also print head. You must install these in your printer.
    Follow the setup guides/manuals that came with your printer. If you can't find them, they're downloadable from Canon's websiteL
    http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp470#BrochuresAndManuals
    Also try:http://www.ehow.com/how_8573333_troubleshoot-not-installed-canon-mp470.html
    Mar 23, 2011 | Canon PIXMA MP470 All-in-One Printer
    Error message says printer heads not installed on canon mp470 how do i fix this?
    On a Canon it means you need a new printhead, the part number is stamped on the side, it starts with QY6-. and you can buy one on line.
    Dec 13, 2009 | Canon PIXMA MP470 All-in-One Printer
    Canon MP470: "Print Head is not installed. Install Print Head"
    Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
    Jul 17, 2009 | Canon PIXMA MP470 All-in-One Printer
    I get error code 5100 on my canon mp470 printer?
    Hi You can Try
    Error Code 5100
    Solution 1:
    Clean the timing strip.
    Solution 2:
    The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
    All The Best: Pineworks
    Mar 17, 2009 | Canon PIXMA MP470 All-in-One Printer
    Need a help for Canon PIXMA® MP470 Printer
    My printer wont print. It flashes Error 5100 and the orange light flashes twice. There are no answers in the book.
    Feb 19, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
    Canon PIXMA MP470 All-in-One Printer Logo
    143 people viewed this question
    old marine
    old marine
    Ekse
    Tareq Bin Mostaq...
    Tareq Bin Mostaq...
