SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
SOURCE: Sharp Atomic Alarm Clock SPC325.
go to the al mode and the just tap the set button. If you hold the set button down it will try to set the alarm. so just tap it and it will change one timezone per tap.
SOURCE: I have 2 clocks (model 40009,40010)that have inaccurate time
I read the manual which said to depress the alarm button. That wasn't the right button but I found that depressing the button next to it, the DST button, that that fixed the problem.
Thanks.
SOURCE: mt atomic clock is always 2 hours slow no matter
How
to Change the Time Zone
Press and hold the “-“ button for 3 seconds the letter P
will appear where the seconds are than press and release the “-“ button until
the correct letter for your time zone appears.
The four time zones are P is Pacific, M is Mountain, C is Central and E
is Eastern Time zone. Press the SET
button to confirm or leave the setting to confirm and exit automatically.
SOURCE: I have a westclox atomic alarm clock - model #700...
I have the same alarm clock the damn thing gives me a heart attack when I wake up. All in all I have the instructions for your clock.
Simple on the back of the device there are five buttons hold down the one that is labeled mode/set then the display will flash use the oC|oF/Up key or Wave/Down key to change the keys and the mode/set the to move between each field.
If you press (not hold) the Mode/Set key you can change the alarm, change the numbers using the degreeC|DegreeF/Up or Wave/Down key to change numbers accordingly.
To turn the alram and snooze function on or off press the Alarm/on\off key.
What I just said may sound complicated but of you press the buttons as I told you then you should have no problems what so ever.
