My kenmore fridge model 10658909802 is not making ice have replaced ice maker but it does not make ice. The light on the right side of freezer blinks a code blink blink pause blink blink and repeats.
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
I have a Kenmore Side by side Refrigerator grab n go style door Model # 72063. The refrigerator is cold but the freezer is not freezing. Ice maker isn't making ice either. Could anyone tell me the part number for the compressor start relay? Thanks!
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
