Question about GE Refrigerators
Ge profile PCR06watss not cooling. evaporator fan runs.
  • GE Master
  • 4,656 Answers
Jerry remove the cover that hides the compressor and feel the top of compressor. Is the compressor running? Hot?
APPLIANCE 911
Posted on Dec 03, 2016
6ya staff
SOURCE:
Refrigerator Not Cooling
Check for any ice build up behind the evaporator cover blocking the fan.
Apr 18, 2018 | GE Refrigerators
GE Profile French door not cooling 70degrees
The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
in other words is there ice frozen all inside if so unplug and take a hair dryer and melt the ice thouroghly
GE Profile French door not cooling Google Search
Feb 04, 2018 | GE Refrigerators
GE bottom freezer stopped cooling
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
My GE profile performance refrigerator is not as cold as it was
is the evaporator fan working, which normally make the food compartment cool.Are the cooling passages clear, if the fan is not functioning, it will create and ice build up which then needs to be defrosted by shutting it down or with a hair dryer or heat gun.
Jun 08, 2014 | GE Profile PSW26P Stainless Steel Side by...
My ge profile refrigerator evaporator fan motor stops while the compressor is running
this is normal as if one compartment is cold enough but not the other compartment the sealed system has a valve in the refrigerant circulation system to channel the refrigerant flow to the compartment that is calling for cooling so that fan will cease operation in the compartment thats cool enough
Dec 14, 2012 | GE Profile Stainless Bottom-Freezer...
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Vish Iyer
Vish Iyer
