When you close the door it will not latch on the bar to lock
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link -
Best Manuals
SOURCE: Driver side door lock stuck
have you tried to pull on the handle on the inside of the door or push the button on the outside while trying to move the latch with a screwdirver
SOURCE: door wont latch shut
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
SOURCE: trunk latch wont hold shut on my 02 cavalier
Make sure it is not binding/sticking where you pull the release cable.
Drench the entire works in WD-40. Push it back and forth until it moves with no resistance.
Make sure the part that hooks onto the latch hasn't come loose enough to not slide over when it makes contact.
If that doesn't work, take the whole thing off. You'll have to anyway to replace it. Chances are with it disassembled you'll see what's wrong.
SOURCE: Oven sef clean latch locked but door is open and I
Ok. Open the door and find the oven light switch(es) (some models had two switches). Press the switch(es) in and see if the latch goes back to the home position. If not enlist a volunteer to turn on the self clean cycle while you are holding the switch(es) in. Just after the self clean starts have them hit cancel and wait until the lock comes back to it's "home" or unlocked position.
Good luck!!
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Richard
Roth
The FixYa Team
