I would suggest firstly checking the drive belt on the mechanism.
Otherwise if not follow these instructions: When you remove the DVD mechanism open the metal case top and bottom. Underneath the mechanism with the bottom cover removed you see a small PCB soldered to the loading motor pins. Remove the small PCB turn the PCB around and you will see a micro-switch on the PCB. Replacing this will solve your problem.
