Tip & How-To about Washing Machines
WASHING MACHINE FAULT CODES AND REPAIRS,
HEAR ARE SOME SITES TO CLICK ONTO FOR WASHING MACHINE FAULT CODES AND REPAIRS.
U-TUBE
1.HOW TO IDENTIFY AN ERROR CODE ON A BOSCH WASHING MACHINE
https://www.youtube.com/watch?v=PvJlqOjG6Uc
2. http://www.espares.co.uk/advice/0/2593/how-to-identify-an-error-code-on-a-bosch-neff-or-siemens-washing-machine-
3. HOW TO CLEAN A BOSCH DRAIN FILTER PLUSS
https://www.youtube.com/watch?v=jAj6oBVrboA
4. WASHING MACHINE REPAIR GUIDE
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/washing-machine-washer-dryer/2967-washing-machine-a-washer-dryer-top-problems-a-common-cures
5. FIVE MOST COMMON PROBLEMS WITH A WASHING MACHINE
https://www.youtube.com/watch?v=-4j8RoesBrg
6. ERROR CODES FOR HOTPOINT PLUSS WASHING MACHINES
http://www.hotpointservice.co.uk/appliances/washing-machines/error-codes/
7. LOGIC WASHING MACHINE ERROR CODES
http://removeandreplace.com/2016/07/18/logik-washing-machine-error-codes-how-to-clear/
8 UK WHITE GOODS LIST OF WASHING MACHINES AND FAULT CODES
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes?start=25
9. LG FRONT LOADER WASHING WASHING MACHINE ERROR CODES PLUS
http://www.searspartsdirect.com/washer-repair/error-codes/lg-front-load-washer-error-codes.html
Washing Machines Logo
2answers
bosch dryer error code E90
Had a E90 fault,bosch condenser dryer found if I disconnected pump plug on the pcb mounted rear rhs of machine, rear connector with 2 red wires, fault would not be present and dryer would run, removed pump cleaned, and spun by hand, reassembled and operated correctly
2answers
Hi. Have a Bosch Loggix 8 VarioPerfect WAS32440AU. It has been displaying a uPd code. Was hoping that you can verify the issue. TIA Brian.
First, of all it is a Bosch "Logixx".
Not a whisper of your fault code anywhere... go to this site and towards the bottom you will see a FORM to ask directly about your specific model AND your exotic fault code! Are you sure you have that "code" right?
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes
Then I found THIS bad news!
"There are a number of different version of the electronics used in Bosch Group made washing machines and washer dryers that are sold as Bosch, Siemens and Neff and most of them use the different fault or error codes when they have a problem or a spare part fails. This particular article relates especially to the range of Logixx washing machines that have an ENR number in the format of WAS****GB/** where the asterisks replaced by a number for each one."
Find a long list of fault codes here:
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Yours is not on the list? Still sure about that number?
Anthony
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
what is f42 fault?
Fault code 04, 05, 21, 42, 43 and 44 all relate to a motor error. So check your motors carbon brushes for excessive wear, check the electrical plug for any damage or corrosion same with the wiring. If your motor is spinning to high-speed straightaway check that tacho connections, and if the problem persists after checking all those areas suspect the PCB or module.
check it out here
Bosch WAQ24461SN Error code E35. Help please. Zita
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3308-bosch-wae-range-washing-machine-fault-codes.html
here is one link to error codes not waq series but will give you an idea
here is a link to a nice little video how to make a good guess whats up and also the error code info you need
usually you find high up codes are something to do with sensors or flow rates on intake etc
sorry cant find the exact error condition you have
a quick phonecall to bosh service department and they can tell you they are very helpfull as a company
Top Washing Machines Experts
john h
