Televison & Video Logo
Huw Jones Posted on Nov 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Goodmans tv is stuck in radio mode, the radio/tv button doesn't change it. How do I get back to tv?
Eddy Kinuthia
Level 3:
Master:
  • Master 235 Answers
  • Posted on Nov 17, 2016
Eddy Kinuthia
Master
Level 3:
Master:
Answers
235
Questions
0
Helped
48949
Points
1252
It is most likely that button is damaged. You can change that button and see if it works.
Lost instructions to my goodmans x pro GPS185DAB radio and I can't change the dab radio station- I am know stuck listening to absolute radio!!!
  • If you wish to download the manual, it is available at:
http://www.devicemanuals.com/support/goodmans-gps185dab-pdf-manual-68602.html
  • To scan for stations; press the Auto button. Press and hold for an international scan.
  • Once stations are stored, you use the UP and DN buttons to find the one you want then press Select
Hope this helps
My Goodmans TV/video combo is stuck on BBC2 with no sound, please help
Switch off TV manually, remove batteries from remote, switch off power outlet and remove plug and wait for 48 hours and retry. Look for any jammed buttons on remote or on control panel. Change input device to something that works like a DVD player and see.
Does anyone know the sky remote code for my goodmans GTVL19W17HDF ? please
Hello
Setup codes for Goodmans TV with Sky remote are:
065 064 100 588 285 037 292 544 207 318 363 399 402 515 527 392 371 245 563 297 584 060 103 263 508 063 616 055
527
055
402
563
662
696
652
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
1helpful
Goodmans 42" LD4 255 HD.\r\nlost remote and using
Yes,ur tv does require a tv orginal remote will help u to used,but the child lock mode must have a secret codes to enter it.Can't turn tv on,must have the tv original remote to enter child lock secret codes though.Tries Goodmans website look for there 1-800.. call ask their customer service they can help to erase the child lock secrect password,if u don't know it.Try website Remotes.com to buy the tv original remote.
Cx80 stuck in rx mode , power cycled, swapped batteries, changed channels, will only swtich to tx when ptt button pressed, otherwise always in rx mode, other radio from package works fine
But thats how a walkie talkie works, it stays in Receive Rx mode UNTIL you press the PTT button,, then it Transmits Tx, and when released it goes back to Rx, receive?
Mode button unresponsive in my 2006 dodge dakota radio.
After sitting all day in the parking lot at work, I started the truck to go home and everything seemed back to normal. There must be some sort of time related reset. I have not tried pushing the MODE button again and probably won't until I need to.
2answers
Goodmans w282ns silver
in your remote control there will be one button calles ASM or auto search mode you press it (or auto) tv will tune one by one channel automatically & it will stop. now from prog. button you can up &down channals. from vol +&- vol up& down. good luck.
Top Goodmans Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
