I tried to determine source, and found some oily substance along the seam of the underside of the door. Ideas?
Certain amount of oil is in the compressor motor casing to stop it burning out
it is under the same pressure as the refrigerant
I would say the oil comes from that casing
you could turn the fridge off at the wall
bring the fridge out to get behind it
and degrease the area to see if the leak is severe
if it is..... needs a fridge technician
not sure
check if cost of replacing the motor compressor unit
on a ten year old ge
might be more that fridge is worth
Testimonial: "Thank you! That is a much more thoughtful than the Monogram support line after researching factory bulletins on my model. As a built-in model, it is quite a job to pull it out! I've scheduled one of their factory techs to come out since he will likely have more familiarity with Monogram than a general refrigerator repair person, since this is a bit odd."
