SOURCE: Ice dispenser only dispenses crushed ice
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
SOURCE: Always dispenses CRUSHED ice
try removing the ice bucket, and on the back wall is a hole approx 1.5 inches square that the brass bar attached to the rear of ice container inserts into,(you may have to put hte container back in partilaly to look under and watch where it slides into) inside thatcut-out is a plunger that slides up and down activating the crushed/cubed option.you can sick you finger in the hole you should seee a plastic hoop that would catch the brasss bar.Try pushing and pulling hte hoop up and down if it does not move freely, youll need to replace the solenoid assy. if it does, then pull allthe way to the lowest positon and make sure when replacing the ice container that the bar falls with in the hoop itself
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
You may not need to replace the solenoid. If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice. Test it manually with your hand, it should be free to move up and down. If not, then it is frozen with ice. Remove the ice dispenser and let it thaw and dry out. You should then be able to move to rod and it will work fine, at least until it freezes again. Anyone know how to prevent it from freezing up? Its a continual problem for me
SOURCE: LG ice maker only dispenses crushed ice not whole cubes
Very problematic issue with this model .Try unplugging and plugging the fridgerator which resets the board.The board is located on top under a removeable panel where the power cord enters....there is a reset/diagnostic button on the board itself.Contact LGUSA.com for any possible warranty and complain like crazy to avoid spending $300 on this board which can be purchased from andrewselectronics.com who is a factory authorized parts provider.Keeping that ice maker going will make you pull your hair out which is unfortuante for such a stylish and expensive fridge.good luck
